the replacement part i received for my microwave is the wrong temperature rating , the original thermostat rating is 150/0 . the part number sent was W10221406 ( thrnst-fix) the temp rating on that unit is 40/56 . the new part shuts down as soon as it reaches the low temp setting . the schematic diagram in the unit identifies the part as a MGT thermostat with KSD1 PR2 and the temp rating( 150/0) stamped on the face . When i match the part to your diagram , i get a thermostat with KSD1 with the temp rating of 40/56 stamped on the face . this part will not work . How do i identify the right part for this unit ?
serial # 11384268GT mfg date 05
I'm looking for one as well. I've found several part numbers, now I'm trying to find them in the local area. Originally Posted by: summv the replacement part i received for my microwave is the wrong temperature rating , the original thermostat rating is 150/0 . the part number sent was W10221406 ( thrnst-fix) the temp rating on that unit is 40/56 . the new part shuts down as soon as it reaches the low temp setting . the schematic diagram in the unit identifies the part as a MGT thermostat with KSD1 PR2 and the temp rating( 150/0) stamped on the face . When i match the part to your diagram , i get a thermostat with KSD1 with the temp rating of 40/56 stamped on the face . this part will not work . How do i identify the right part for this unit ?
serial # 11384268GT Manufacturer date 05
