I had the repair man out today to look at my 4 yr old Duet. It makes a hell of a racket in the spin mode and I suspected that a bearing was shot. He told me the main bearing was gone. They want $900.00 to fix it. On a 4 year old machine !!!! Soooo.....anyone else had this problem ?? Can I fix it myself ?? What would the parts cost ??? Any help or info would be appreciated !!!! JZ in CT :confused:
Probably looking at $251 plus shipping for rear shell assembly, part # AP3773841.Crunch into Google "Whirlpool washer Duet job aid" and download it. A lot of work, best to support shell inside washer with wooden blocks while removing supports, also best to remove any items that could be smashed. Probably 3 to 4 hrs time, may have to use penetrating oil on spin basket shaft and pound out shaft with wood mallet. Good luck, I try to avoid doing this job.
Geeze, $900 says "I do not want to do this job!"
I Quote $600 to do it. It is frustrating to see people price gouge like that.
It is a HUGE job, though. The Neptune is alot easier.
Matt
