REM property
#1 Posted : Thursday, June 25, 2009 6:53:54 PM(UTC)
REM property
I had my kitchen redone about a year and a half ago all worked fine,about 6 months ago the oven started tripping breaker(micro worked fine). There is a 30A with 10gage to oven (which ge said was fine) Replaced breaker and I have 121v out of each leg of breaker. when I hooked up the oven it tripped and now the breaker will not even stay set. I disconnect the oven and breaker stays set,Am I to assume the problem is in the oven?
Thanks in advance
Dan O.
#2 Posted : Friday, June 26, 2009 9:53:31 AM(UTC)
Dan O.
Quote:
I disconnect the oven and breaker stays set. Am I to assume the problem is in the oven?
It sure sounds like it to me.
JMO
Dan O.
www.Appliance411.com
The Appliance Information Site
=D~~~~~~
