fivermillions
#1 Posted : Tuesday, December 25, 2007 8:39:24 AM(UTC)
fivermillions
The top oven does not heat on any option (bake, broil, etc).
Recently the top oven would heat incorrectly - select 375, it would show 375 but not reach temperature. If the oven was turned off and restarted quickly it would show ~250 deg, then climb to 375.
But, now no heat generation at all.
Also, no error codes, control panel replaced about 2 years ago.
#2 Posted : Tuesday, December 25, 2007 11:57:06 AM(UTC)
Most likely the problem with your oven is a bad control board.
- The part number for the control board is AP3155970
- Here are the break down diagrams for the GE oven Model JTP56WA1WW
Happy Holidays!
GE Oven temperature Bad (Oven Repair (including Ranges and Cooktops))
by jeffdroy 12/22/2009 9:54:55 PM(UTC)
GE Oven Temperature Swings (Oven Repair (including Ranges and Cooktops))
by elmo123 3/9/2009 5:31:25 PM(UTC)
GE Oven Temperature In Accurate (Oven Repair (including Ranges and Cooktops))
by mkgunnels 1/5/2009 4:03:59 PM(UTC)
