Jerry Price
#1 Posted : Monday, June 22, 2009 9:39:36 AM(UTC)
Jerry Price
Our front loading washer will not despense fabric softener. I have replaced the electric valve, made sure all hoses and openings are clear and it still will not work. Do you have any suggestions as what to do next?
sidfink43
#2 Posted : Tuesday, June 23, 2009 2:44:25 PM(UTC)
sidfink43
Since you have replaced the electric solenoid, the likely problem is the timer is not sending 120 volts to the solenoid.
Check the voltage by advancing the timer to the point where fabric softener is supposed to enter the washer and check the voltage coming to the terminals from the wiring. If there is not 120 volts you will have to replace the timer.
Good luck, let us know what you find out.
Bleach and Fabric softener dispenser issue (Washer Repair)
by MPHCO 10/7/2012 9:39:32 AM(UTC)
Fabric Softener dispenser not working (Washer Repair)
by KellyJ 4/16/2012 9:30:30 AM(UTC)
Fabric Softener Dispenser problem (Washer Repair)
by Sque 2/4/2012 6:39:30 PM(UTC)
Fabric Softener Dispenser Problem on Whirlpool LA7680 (Washer Repair)
by skuddle 11/29/2011 9:34:26 AM(UTC)
Fabric Softener Dispenser (Washer Repair)
by cobiacircle 2/12/2011 5:41:34 AM(UTC)
Samsung fabric Softener Dispenser (Washer Repair)
by TX2110 11/18/2010 5:08:26 AM(UTC)
Soap in fabric softener dispenser (Washer Repair)
by perltech 3/2/2010 2:59:06 PM(UTC)
Whirlpool fabric softener dispenser (Washer Repair)
by rickmc11 6/12/2009 4:24:29 AM(UTC)
fabric softener dispenser removal (Dishwasher Repair)
by Mack1203 1/13/2009 4:26:42 PM(UTC)
loose fabric softener dispenser (Washer Repair)
by deanber 2/21/2008 5:30:03 AM(UTC)
Neptune Fabric softener dispenser problem (Washer Repair)
by nander 2/4/2008 4:55:19 AM(UTC)
by Pam Denny 9/12/2007 12:06:31 PM(UTC)
