LBELSTON
#1 Posted : Sunday, June 21, 2009 9:02:34 AM(UTC)
LBELSTON
I need help replacing the belt on the motor.
sidfink43
#2 Posted : Monday, June 22, 2009 12:04:40 PM(UTC)
sidfink43
You will have to
1. Remove the front panel and release tension on the belt
2. Remove the motor with the pump assembly
3. Remove the pump
This will allow you remove and replace the belt.
Although it can be a one person job, the motor is heavy and awkard to remove and replace and I recommend having a helper.
Good luck, let us know how it turns out.
WASHER belt replacement (Washer Repair)
by texaslonghorn 6/8/2012 8:42:47 PM(UTC)
Washer Belt replacement (Washer Repair)
by spam_warrior 12/29/2011 4:56:13 PM(UTC)
washer belt replacement (Washer Repair)
by vetsvett 8/24/2010 5:31:53 PM(UTC)
white westinghouse washer belt replacement (Washer Repair)
by Kmcduffie 4/13/2010 11:34:26 AM(UTC)
Maytag Washer Belt Replacement (Washer Repair)
by promoguy 11/19/2009 9:39:33 AM(UTC)
by topcatpinson 4/12/2009 4:49:46 PM(UTC)
Kelvinator Washer belt replacement? (Washer Repair)
by Eric Kelsheimer 8/24/2007 9:05:45 AM(UTC)
