candace52979
#1 Posted: : Sunday, June 21, 2009 9:02:14 AM(UTC)
candace52979
Yesterday, I turned my dryer on to dry some clothes and it would not dry the clothes. There is no heat. The dryer knob on the Automatic Setting but won't spin but the Timed Dry knob spins. I tried drying the clothes again & I set them dry for about 1 hr. and the clothes are not drying. I am told there's no heat and the problem might possibly be the "Heating Element" is broken or it could be 'fuse'. PLEASE HELP! What is the problem???
#2 Posted : Monday, June 22, 2009 2:39:59 AM(UTC)
Replacement parts for WHIRLPOOL REX3514RQ1 | AppliancePartsPros.com
Here is a wiring diagram
https://www.servicematters.com/d...0Sheet%20-%208576793.pdf
Could be either of the parts you listed.
The circuit path for the heater is: L1 , TIMER SWITCH 2 , THERMAL CUTOFF NOT RESETTABLE (thermal fuse) , OPERATING THERMOSTAT , HI LIMIT THERMOSTAT , HEATER , centrifugal switch 1M/2M , L2
Check the heat element first as you can visually confirm if it is open.
Next would be the thermal fuse. This is the one mounted on the heater case. Best is to remove one wire from it and check it with a meter, should be 0 ohms.
Jiggery pokery method is to short the two wires to the fuse together, tape them up so they cannot short to the frame, plug the unit in and give it a try.
If the fuse is blown check you vent system, drum seals and blower to be sure that one of these was not the cause for the blown fuse.
Next would be the thermostats both should be 0 ohms at room temperature.
Always unplug the unit when working on it 240 volts is lethal!!
