Amygirl75
#1 Posted : Friday, December 9, 2011 9:04:18 AM(UTC)
Amygirl75
My dryer seems to be working fine, exlcuding the display lights on the far left side of the control panel. They do not light up at all. These are the lights for time dry, sensor dry, wrinkle release, air fluff, and the heat levels. All other lights work fine. The dry commands seem to be getting sent to the logic board because the dryer still runs when I make a selection; I just can't tell what type of cycle/heat level I am selecting. I re-seated the cables from the control panel/membrane to the logic board to be safe. Is the issue with the control panel/membrane or is it the logic board? Or simply a bad cable?
Joe / APP Team
#2 Posted : Friday, December 9, 2011 10:55:28 AM(UTC)
Joe / APP Team
Amygirl,
Since you've checked the harnesses, and everything works except the lights, you'll need to replace the control console,
Part number: AP4039020
The control console contains the LED lights and circuitry for the lights to operate.
Good Luck,
Amygirl75
#3 Posted : Friday, December 9, 2011 11:54:28 AM(UTC)
Amygirl75
Fast response! Thanks Joe!
Amy
Joe / APP Team
#4 Posted : Friday, December 9, 2011 12:29:53 PM(UTC)
Joe / APP Team
Amy
Amygirl,
Thanks, we try our best, You'll be even happier once you get the control panel replaced.
Thanks,
