lisalecompte
#1 Posted : Friday, June 19, 2009 8:22:47 AM(UTC)
lisalecompte
My Washer Will Not Agitate. It Fills With Water Than Stops. I Can Get It To Spin And Drain. Please Can Anyone Help!
#2 Posted : Friday, June 19, 2009 2:26:52 PM(UTC)
Does the motor run when it should agitate?
lisalecompte
#3 Posted : Thursday, June 25, 2009 3:38:41 PM(UTC)
lisalecompte
Gene Thanks Yes The Motor Is Running
#4 Posted : Thursday, June 25, 2009 8:43:28 PM(UTC)
Remove the washer cabinet and check the drive coupling (#13 on the diagram). The disassembly instructions are attached to the reply.
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL LSQ9200LQ1 | AppliancePartsPros.com
Handles attachments
How to remove the washer cabinet.doc (25kb) downloaded 8 time(s).
How to remove the pump.doc (25kb) downloaded 3 time(s).
How to replace the motor drive coupling.doc (25kb) downloaded 5 time(s).
