jev
#1 Posted : Wednesday, December 7, 2011 5:34:31 PM(UTC)
jev
Dryer runs. Tumbler works. It just decided to quit heating. No heat at all. how do I trouble shoot what to replace? Is it a Heating Element, Thermal fuse, Thermal cut off kit, cycling thermostate, High limit thermostate or what else? :confused:
Thank you.
ApplianceJunk
#2 Posted : Wednesday, December 7, 2011 5:45:50 PM(UTC)
ApplianceJunk
Hi,
The most common thing would be that the heating element simple burnt out.
This is how I would troubleshoot it.
1. Check voltage to the dryer with my multimeter to make sure I had 220-240 Vac to the dryer.
2. Remove the back of the dryer and ohm out the heating element with my multimeter.
3. If the heater was ok I would next check the high limit thermostats on the side of the heating element.
If you don't have a multimeter to do these check you may also be able to simple remove the heating element and just look at the coil to see if there are any breaks in the element. If there are it needs to be replaced.
jev
#3 Posted : Wednesday, December 7, 2011 5:56:26 PM(UTC)
jev
Thank you! I will check it out and let you know how it works.
ApplianceJunk
#4 Posted : Wednesday, December 7, 2011 6:08:32 PM(UTC)
ApplianceJunk
Your welcome, let us know what you find.
Whirlpool Dryer won't heat (Dryer Repair)
by spelding 9/16/2016 5:48:12 AM(UTC)
by wgomezp1 10/12/2015 4:49:48 PM(UTC)
Whirlpool dryer won't heat during auto cycle (Dryer Repair)
by Pdcrull 9/7/2014 8:52:29 PM(UTC)
Whirlpool Dryer Won't Heat (Dryer Repair)
by rebecca0101 9/4/2014 10:46:27 AM(UTC)
Whirlpool dryer won't heat (Dryer Repair)
by Rans 2/12/2010 11:52:28 AM(UTC)
Whirlpool Dryer won't heat up (Dryer Repair)
by jmrobeck 9/2/2008 10:59:58 AM(UTC)
by haddy 8/14/2008 7:44:34 PM(UTC)
