jbonjbon
#1 Posted : Thursday, June 18, 2009 9:09:39 AM(UTC)
jbonjbon
Two yr old washer won't spin. Other phases of cycle run ok ie fill agitate drain although lately have noticed sound of residual water in the tub (not visible in the basket) as the basket comes to a stop. Sounds like an object plowing through water. So water not draing completely at the end of the spin cycle. Clothes would come out still wet requiring a second spin. It is possible to rotate the basket manually although it takes some effort.
richappy
#2 Posted : Thursday, June 18, 2009 9:46:03 AM(UTC)
richappy
If the spin basket will spin up to full speed without clothes in it, you have a bad clutch. If water still left in the tub at the end of spin cycle, you may have something partially blocking the tub drain or somethin in the pump.Post results
jbonjbon
#3 Posted : Thursday, June 18, 2009 10:47:51 AM(UTC)
jbonjbon
Basket will not spin when empty. Could the clutch still be the problem or is it more likely that the drive coupler or basket drive block is the culprit. Is the fact that tub is not draining completely related to the spin problem or is it a separate issue?
richappy
#4 Posted : Thursday, June 18, 2009 12:44:08 PM(UTC)
richappy
You probably have a busted coupler. Just remove pump and motor and check
jbonjbon
#5 Posted : Friday, June 19, 2009 8:36:20 AM(UTC)
jbonjbon
Removed case to expose motor and coupler which looks like new. Plastic couplers and rubber ring intact; no rubber bits on the floor to indicate wear. I poked at the clutch plate with a screwdriver and it does not seem lose or off center although there was a small amount of black dust on top of the transmission case directly below the clutch.
richappy
#6 Posted : Friday, June 19, 2009 8:53:57 AM(UTC)
richappy
Turn the tranny coupler clockwise till the spin basket engages. If very hard to turn, you either have something stuck in the tub, or dragging brake shoes. If so, go to my "sticky" "replacing direct drive washer brake shoes" for info on this.
3 year old top loading washer won't spin clothes dry (Washer Repair)
by craig100 3/15/2024 9:35:49 AM(UTC)
Samsung washer won't spin (Washer Repair)
by Guest 1/8/2022 10:56:39 AM(UTC)
Maytag Washer won't spin or complete cycle - FIXED! (Washer Repair)
by jimjokjv 10/1/2021 10:08:04 AM(UTC)
Whirlpool WTW4815EW1 Washer Won't Spin or Agitate (Washer Repair)
by dann1551 4/7/2021 8:42:00 AM(UTC)
Maytag performa washer won't spin. It drains and i can hear the motor but tub appears stuck. (Washer Repair)
by Brittrepairs 12/21/2019 7:47:28 PM(UTC)
Whirlpool LSN2000LW Washer Won't Spin, Buzzes (Washer Repair)
by Robb235 2/21/2019 4:21:02 AM(UTC)
Washer won't spin out. (Washer Repair)
by DJChad818 10/26/2017 9:47:20 AM(UTC)
Washer won't spin (Washer Repair)
by Fingers123 10/22/2017 1:43:41 PM(UTC)
Washer Won't Spin (Washer Repair)
by je00409 9/5/2017 11:00:04 AM(UTC)
Washer won't spin or agitate (Washer Repair)
by dhughes 4/1/2017 10:17:04 AM(UTC)
Whirlpool belt drive washer won't spin. (Washer Repair)
by weswoodallz21 3/21/2017 7:08:08 AM(UTC)
Maytag Washer won't Spin just Hums (Washer Repair)
by bnweth 1/4/2017 8:29:35 PM(UTC)
Whirlpool washer won't spin or drain (Washer Repair)
by ronaldjp1 1/3/2017 2:58:09 PM(UTC)
maytag washer won't spin fast (Washer Repair)
by benp1 12/21/2016 5:14:31 PM(UTC)
by lmhansgen 8/31/2016 10:19:23 AM(UTC)
