Disconnecting and taking out Ice maker from freezer will this cause an issue? Ice maker has never been used and not water hoooked up to it.
Hi,
Disconnecting and taking out Ice maker from freezer will not effect how your refrigerator works.
May I ask why you want to remove it?
Originally Posted by: ApplianceJunk ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Hi,
May I ask why you want to remove it? It just gives me more room in the fridge since its not used. My fridge is not cooling up top i have to defrost fins to get it to cool again. Ive had to do this 2 times already. hoping that removing the ice maker wasn't causing this issue even though i took it out after this occured. do you have an idea of what it could be?
Originally Posted by: ApplianceJunk ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) I had this issue when i first got the unit. the Jazz board and thermostat were replaced. is the Jazz board the contrl board? is this simple to replace? Once i defrost the fins the fridge works good untill about a montg later when i have to do this again.
Quote:is the Jazz board the contrl board? Yes it is the same board. I have no idea how handy you are, but I feel it's a fairly simple part to replace.
Originally Posted by: ApplianceJunk ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Yes it is the same board.
I have no idea how handy you are, but I feel it's a fairly simple part to replace. Is the board in the fridge on the top by the lights? I'm a tech so i should be able figure it out.. Are the control boards a common issue? how else can i test to make sure that is the problem not something else? thanks for the help by the way..
Quote:Is the board in the fridge on the top by the lights? Yes it is. Quote:Are the control boards a common issue? They have been for me. Quote:how else can i test to make sure that is the problem not something else? Here is a copy of the tech sheet for your model refrigerator. It includes some troubleshooting information that you may find helpful.
