Hazel
#1 Posted : Friday, December 21, 2007 7:34:53 AM(UTC)
Hazel
My front load washer is leaking at the bottom of the tub at the bolts.
richappy
#2 Posted : Friday, December 21, 2007 12:57:18 PM(UTC)
richappy
Try tightening each bolt, if any are stripped out, you will need a tinerman nut on the other end.
If it still leaks, you will need to install a new seal between the tub halves, sort of a big job. If so, go to www.applianceaid.com for info on this. Also, while apart, it would be a good idea to clean and rust proof the aluminum alloy spider supports.
