leftenant
#1 Posted : Tuesday, June 16, 2009 1:31:32 PM(UTC)
leftenant
I just replaced the ignitor on the bake portion of the oven and it seems to be working fine now. Now the problem is that only one side of the burner bar on the ignitor side seems to be lighting and the other side is not. What could cause this problem? I made sure everything is back in the exact same place. tried with the cover on and off and the other side of the bar still is not lighting. :( :confused:
#2 Posted : Tuesday, June 16, 2009 5:23:53 PM(UTC)
Make sure all holes on the burner are open and there are no burned through holes. Otherwise the burner has to be replaced.
