jwkriz
#1 Posted : Tuesday, June 16, 2009 2:52:08 AM(UTC)
jwkriz
I just ordered the Drain tube freeze up kit (AP4246987). Per the on-line chat session, the kit does not come with instructions. Is the installation made entirely through the freezer section compartment (on top in this model)? Any assistance would be appreciated.
vetteman
#2 Posted : Tuesday, June 16, 2009 6:01:46 AM(UTC)
vetteman
Dont know what kit you have but when I installed auxillary drain heaters (non factory) I had to heat the drain area up and use foil tape to secure the heater onto the pan. Heating with a heat gun (hair dryer) was necessary otherwise the tape would not stick. Drain heaters I used were skinny braided heaters with different wattages for different applications. a small 10-30 watt heater should suffice. I wired in parallel with defrost heater and installed a small portion of it into the drain hole itself.
MarkDA
#3 Posted : Tuesday, April 20, 2010 6:20:40 AM(UTC)
MarkDA
Just wondering if you recieved adequate information to install the kit? I believe I need one as well (after 15 years of operation) and want to make sure I can do the job without tearing the whole thing apart only to discover I need a special tool or stand on my head for 30 minutes. Thanks . I have a TJ18NL and I have considered the possibility that I may already have a freeze drain heater since the system has worked for so long? Any help is appreciated.
MarkDA
#4 Posted : Wednesday, December 8, 2010 4:03:35 PM(UTC)
MarkDA
My kit did include instructions, not real clear buy adequate. The new freezer block did slide in with some difficulty, it may have been the way I installed the tape. Anyway, time will tell if it works or not. A new problem arose and now the refrigerator maintains a temperature close to 30F, too cold.
