jeff stoneburner
#1 Posted : 13 years ago
jeff stoneburner
control panel will not power up.
ApplianceJunk
#2 Posted : 13 years ago
ApplianceJunk
Make sure you have 220-240 volts going to the range. Next I would check the screws that connect the power cord to the range to make sure they are tight.
If you don't find the problem there then I would simply trace it back with my volt meter to see why I was not getting power to the control panel.
