Gene D
#1 Posted : 17 years ago
Gene D
Ice Maker overfills with water causing thick cubes. Cubes sometimes do not drop due to cube thickness.Water spills over into ice container while filling. Tried changing inlet water valve and this did not solve the issue.
kawfeeman
#2 Posted : 17 years ago
kawfeeman
you may be able to remove cover from icemaker and turn down the amount of time the icemaker calls for water ...there is usually a philips screw mounted sideway kind of in the upper right corner and you want to turn in a 1/4 turn to the "-" sign...
Gene D
#3 Posted : 17 years ago
Gene D
Jim:
Found what looks like a plastic screw with a slot in the location you mentioned after removing the cover. There is no "-" or "+" so I tried turning it counterclockwise. If anything, it seemed worse so I turned it back to original and then clockwise a good 1/2 turn. I will let you know how I make out.
Gene D
Gene D
#4 Posted : 17 years ago
Gene D
Jim:
Adjusting this screw did not make a difference either way. Could it be something else besides the ice maker itself or the water fill valve?
Gene D
kawfeeman
#5 Posted : 17 years ago
kawfeeman
possibly a watervalve situation where it is not seating properly, but somewhat unlikely ... try turning the screw another 1/2 to 3/4 turn clockwise ...
Gene D
#6 Posted : 17 years ago
Gene D
tried turning clockwise 1 full turn, still spill water over. It does not seem as if it will go in any more (clicks). Should I try counterclockwise again?
kawfeeman
#7 Posted : 17 years ago
kawfeeman
ok.. is this the screw ( metal ) within the center of a large plastic gear ?
Gene D
#8 Posted : 17 years ago
Gene D
No its a plastic screw on the outside of the icemaker on the side that you see when you look inside the freezer after removing the cover. Nothing elses is on the outside of the icemaker. I had it out of the freezer. You need to remove 3 screws to get inside where the motor is. Is there anything to adjust in there?
Samsung Ice maker overfilling tray (Refrigerator & Freezer Repair)
by kb5oze 13 years ago
Ice maker overfilling (Refrigerator & Freezer Repair)
by chipmanning 14 years ago
Ice maker overfilling with water (Refrigerator & Freezer Repair)
by jacknbevd 16 years ago
