Dryer has been running fine and all of a sudden. No Heat. Still running, just no heat. I took the dryer completely apart and it was full of built up lint inside. I'm going to clean it out completely. I was wondering if I should be replacing a part.
Originally Posted by: jsanabia ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Dryer has been running fine and all of a sudden. No Heat. Still running, just no heat. I took the dryer completely apart and it was full of built up lint inside. I'm going to clean it out completely. I was wondering if I should be replacing a part. If it is a gas dryer your igniter is probably bad. This is what lights the gas to start heating. Some units have a little hole you can look trhough to see if it is on (it may have a plastic cap) On my kitchen aid it is in the lower left front. When you turn on the dryer you should see a red glow before the gas is turned on, then it turns off. CHeck this site for a repair kit and you may find more info.
