m&r
#1 Posted : Saturday, June 6, 2009 12:34:04 PM(UTC)
m&r
My ice maker dispenses too much water which overflows into the freezer. Does anyone know how the water is metered or controlled?
Thank's
woodchuckie
#2 Posted : Saturday, June 6, 2009 2:01:46 PM(UTC)
woodchuckie
Take the plastic end cover off the ice maker and look for the symbols + - and turn it to the -.
OR
Your water inlet valve on the back bottom of the unit may be slow to shut off and causing it to overflow.Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. You can see then if it shuts of quick enough.
m&r
#3 Posted : Monday, June 8, 2009 11:31:07 AM(UTC)
m&r
Hello woodchuckie,
I took the cover off but don't see +- anywhere. There is what appears to be a small clear plastic adjuster on the front under the white cover, would this be the thing. I'm guessing anti clockwise for less?
Thank's
Mike
woodchuckie
#4 Posted : Monday, June 8, 2009 12:45:13 PM(UTC)
woodchuckie
I'm not sure what it is but it won't hurt to try it. Yes it should be anticlockwise.
Ice maker water overflow (Refrigerator & Freezer Repair)
by prniners 7/22/2012 7:47:30 PM(UTC)
Ice Maker Water overflow (Refrigerator & Freezer Repair)
by ashappelle02 11/14/2009 8:59:48 AM(UTC)
ice maker water overflow (General Talk)
Belarus coneman 12/13/2007 7:02:56 AM(UTC)
