The oven does not maintain temperature. The readout on the control pannel says that it is working at proper temp. Took two hours to bake brownies!! I replaced the thermostat in the oven, but that didn't fix the problem. Both the bake and broil elements get hot when they are turned to bake or broil. Any help?? Thank you rob21863@yahoo.com
Assuming the part you called "the thermostat" is the oven temperature sensor and you already have replaced it, then the problem is the oven control board. Unfortunately this part is no longer available.
As a temporary solution (before you buy a new range) you can measure the difference between the real temperature in the oven and the set temperature and, every time you cook, set the temperature plus the difference.
Yes Gene, That helped a lot. Now I can replace the range and not feel bad! Thanks again. Robert
