bulldozerbob
#1 Posted : Monday, December 17, 2007 9:49:15 AM(UTC)
bulldozerbob
Washer works perfectly through all cycles but water won't fill up all the way to the full level in any cycle. Should I go straight for the water inlet valve or could it be something I'm unfamiliar with? And no, there are no leaks.....Thanks a million....Bob
abbie
#2 Posted : Monday, December 17, 2007 12:32:32 PM(UTC)
abbie
did you try to reset your water level switch, if so the water level[pressure] switch could be bad .
