Hi, When I press the Hold Start button on my washer the machine no longer starts. All the lights on the control panel are working and switching modes are working but the machine wouldn't start. Can you help? If its a fault in one of the circuit boards then I can change that, but which one.
just out of curiousity, if you remove the three screws that hold the kick / toe panel on, is there a little packet with troubleshooting info... you'll need to access the service mode to determine fault code..
