The washer will not stop filling with wa ter even after water level is reached:confused:
if you turn the washer timer ( with tub empty ) to fill ( warm water ) and let it fill for 30 - 60 seconds and then pull the plug, if water still comes in , then you have a bad water inlet valve...
