klamath
#1 Posted : Friday, December 14, 2007 3:13:30 PM(UTC)
klamath
Fridge/Freezer runs constantly all copper tubes leading to and from compressor at room temperature, after running for a hour the freezer and refrigerator compartments are has at room temperatue. My thoughts are that the timer is burned out or stuck in the defrost mode and heater is on all the time. My plan of attack at this time is pull the timer and run some test on it. Your thoughts on the problem.
Thanks---chuckhouston@gmail.com
#2 Posted : Friday, December 14, 2007 3:29:39 PM(UTC)
Does the compressor run?
If it does then it's nothing to do with the defrost system.
Most likely the problem in such case is with the sealed system.
klamath
#3 Posted : Saturday, December 15, 2007 11:15:57 AM(UTC)
klamath
Gene,
Thanks for the prompt reply, I have been trying to avoid a trip to town 50 miles over snow covered mtn. pass, the compress runs but you are correct on the problem, probably low on R134 or what ever,Thanks again and I will post results later, after I get fixed.
