Turned the oven on to bake and it suddenly got a mind of its own it turned to clean mode said the door was locked and wasn't. I had to unplug the stove when it cooled a little the door did lock. Waited till the oven cooled down some and plugged back in. It cleared all codes but the oven was still heating. What am I looking at to replace ? Or would it be better to buy a new one?
Sounds like the control board has gone bad. The model number you posted is incomplete.
Thanks for the quick reply sorry I forgot the 665. 95775890
Those control boards are also different in color. What is the color of the key panel in your range?
The face is white. I took notice the broiler is the only thing that turns on by itself. Can I unhook that temporarily so I can use the cooktop
Originally Posted by: blackcote ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) ...Can I unhook that temporarily so I can use the cooktop... It is possible, but I do not know how to do it with your range because I do not have the wiring diagram. You have to find the live wires connected to the control board, draw a picture of their connection to the control board, so will remember how to connect them to the new part, disconnect and insulate them. - The part number for the control board is AP3119177Gene.
Thanks Gene you have really been helpful. It is much appreciated
