:cool: WASHER WILL RUN THROUGH WASHING CYCLE. WHEN IT GOES TO DRAIN CYCLE IT CUTS OFF. THE MOTOR IS NOT RUNNING & I HAVE CHECKED THE PUMP & DRAIN LINES. I DIDN'T FIND ANYTHING WRONG . COULD IT BE THE TIMER OR CONTROL BOARD:confused:
First thing I would check is the lid switch or the strike on the lid that fits in the hole in the cabinet THE SWITCH SHOULD MAKE A CLICKING NOISE WHEN YOU TEST IT.
I checked it everything is o.k. with the lid switch? Do you have any other suggestions .
