denisegraham
#1 Posted : Thursday, May 21, 2009 4:52:38 PM(UTC)
denisegraham
:confused: have an older model electric GE dryer that worked well until 2 days ago did have to tumble heavy loads twice lately, but turned it on 2 days ago went thru entire cycle and when I opened door the clothes were cold and wet. we took the heating element off and carried by a parts place and they tested it but it was fine what else could it be?
captron1954
#2 Posted : Friday, May 22, 2009 2:30:41 PM(UTC)
captron1954
Hi Denise, I'm far from an expert........I know from past experiance that the heating elements are similar to those of a toaster ( a giant one), and when they do go out then they can be restrung. The problem is that one of the coils breaks (looks like a large spring). That's my problem, only my biggest problem is I can't recall how to open the dryer cabinet to remove the element. If your element is ok, I would look at the thermostat, and or check your fuse/breaker box and see if it is getting full voltage. There is probably also a safety thermostat that could malfunction, and keep the heat element from heating up. Good luck
denisegraham
#3 Posted : Sunday, May 24, 2009 12:07:36 PM(UTC)
denisegraham
:rolleyes:
Thanks for the advise.
We looked up how to get the dryer apart on here, under our type of dryer. You should be able to also.
