silverbay
#1 Posted : 13 years ago
silverbay
The part replacement for the defrost timer has a black wire that was not on the original part. I have confiremd that this is a replacement but the are options for the black wire depending up the original wiring diagram of the unit. I chose version2/procedure 3 as it seemed to fit.
The new part prevents the compressor from running even though the temp is hot --the old part at least ran the compressor at the same temp.
I unplugged the refrig while changing out parts and then plugged it back in -- is there some other thing I should expect when a new timer is inserted?
Is this option wire make any sense or do I still have the wrong part?
#2 Posted : 13 years ago
Looks like you used the4 right version and procedure.
I am assuming that the compressor and both fans are not running.
Are you sure you are not in a defrost cycle.
Give it half an hour to see if it fires up or turn the timer cam to see if it will fire up.
richappy
#3 Posted : 13 years ago
richappy
Your timer will not advance if you failed to put the wire into the timer pins. All the modern Whirlpool fridgs. I have seen have that wire stuck in the middle pin of the timer. There will be 4 pins and one isolated, stick the wire in the middle pin of the three pins that are close together.
silverbay
#4 Posted : 13 years ago
silverbay
Thanks denman -- all I did was advance the timer to run stage and the compressor kicked in. i should have thought of that! I assume it will get to a defrost sometime.
