Dougwjackson
#1 Posted : Monday, October 31, 2011 3:16:53 PM(UTC)
Dougwjackson
I found that a penny had been launched into the plastic tub of the washer and caused a hole, leaking profusely.
I took the tub out and separated the halves, and want to know if the plastic is repairable with fiberglass or perhaps with a PVC glue and plug.
The hole is actually the thickness of a penny and almost as wide, so it is a slit. I figured I could repair this, but I am unsure of the type of plastic and if fiberglass or epoxy will stick permanently to it.
Any ideas?
Thanks, Doug
sidfink43
#2 Posted : Wednesday, November 2, 2011 6:04:46 PM(UTC)
sidfink43
I don't know. I would try a good two part epoxy, which I think will work.
Good luck, let us know how it turns out.
