fayef
#1 Posted : Thursday, October 27, 2011 8:54:29 AM(UTC)
fayef
My whirlpool ultimate care II washer makes a very loud noise at the end of each spin cycle (wash & rinse). You can turn the basket with your hand, when it gets to a certain spot it "thumps" loudly; you can continue to turn the drum and half way around it "thumps" again. I took the cabinet off and found 2 plastic cups which each contained a brass colored pin. The pins are approx. 1/4" square & about 1-1/2" long with a hole in the pointed end where maybe a clip or something should go through. They have been installed above the plastic cup as there are wear marks on the pin. It looks as if the only purpose for the plastic cups is to make sure they don't fall into the motor. I have searched the exploded view and cannot find these pins nor cups. Also you can put your hands in the washer on the side of the basket and raise it up a little, my neighbor's washer wouldn't come up any, is this normal? Is there anything you can tell me about what might be wrong?
richappy
#2 Posted : Thursday, October 27, 2011 3:41:56 PM(UTC)
richappy
Looks like you have a bad drive block that holds the basket to the spin tube, part AP2905773
You will also need to buy the special spanner wrench to properly tighten it. Call this site for the part #
If that part is ok, you have a bad spin tube, go to my sticky "replacing direct drive washer brake shoes" for info.
fayef
#3 Posted : Friday, October 28, 2011 9:18:18 AM(UTC)
fayef
Thank you for info - we have ordered parts & spanner wrench - my question is you did not mention the 2 brass colored pins which seems to have fallen from somewhere under the tub. They are not shown in the exploded view nor is there a part number for them.
Thanks again
richappy
#4 Posted : Saturday, October 29, 2011 1:02:50 AM(UTC)
richappy
They are shipping pins, not needed. What was your problem, worn spin tube?
Guest
#5 Posted : Wednesday, October 6, 2021 11:36:36 AM(UTC)
Guest
Groups:
Is there a heating element in the Ultimate Care
Whirlpool Ultimate Care II Washing Machine (Washer Repair)
by Guest 1/20/2023 8:42:21 AM(UTC)
Whirlpool Ultimate Care II LSQ8243HQ0 won't spin (Washer Repair)
by williamlee 4/7/2021 4:58:55 PM(UTC)
Whirlpool Ultimate Care II GSQ9364HQ0 (Washer Repair)
by skylightmissing 6/8/2020 3:51:54 PM(UTC)
Whirlpool Ultimate Care II, how do u remove Agitator Cam? (Washer Repair)
by DieselDavy 4/18/2020 5:07:51 AM(UTC)
whirlpool Ultimate Care II (Washer Repair)
by johnep33333 4/19/2017 6:21:30 PM(UTC)
Whirlpool Ultimate Care II won't spin consistently/maybe not draining? (Washer Repair)
by LauraSpillman 11/2/2016 12:42:13 PM(UTC)
Whirlpool Ultimate Care ii makes strange noise on spin cycle (Washer Repair)
by m042926 2/10/2015 5:38:41 PM(UTC)
Whirlpool Ultimate Care II cycle issues (Washer Repair)
by bisley45 1/25/2015 6:08:52 PM(UTC)
Whirlpool Ultimate Care II dryer will not start (Dryer Repair)
by jajinnette 12/14/2014 10:09:44 AM(UTC)
Whirlpool Ultimate Care II problem (Washer Repair)
by uri 8/11/2014 7:25:44 AM(UTC)
Whirlpool Ultimate Care II help (Washer Repair)
by eelaroo2 4/8/2014 6:40:25 AM(UTC)
Whirlpool Ultimate Care II wont spin at the end of the cycle....motor humms. (Washer Repair)
Belarus tmv1962 12/19/2013 4:25:19 PM(UTC)
whirlpool ultimate care II washer help!! (Washer Repair)
by baseballmommy3 11/3/2013 1:08:54 AM(UTC)
Whirlpool Ultimate Care II Stuck (Washer Repair)
by thebeginning99 10/20/2013 7:28:45 AM(UTC)
whirlpool ultimate care II (Washer Repair)
by smith96 10/15/2013 9:40:30 AM(UTC)
