jwes
#1 Posted : Monday, May 11, 2009 4:46:02 AM(UTC)
jwes
My Maytag dishwasher has no power to the front control panel. I checked the door switches and found that they are functioning properly. I do have line voltage going into the circuit board. That appears to limit the problem to either the circuit board or the control panel. How can I determine which is the problem?
#2 Posted : Tuesday, May 12, 2009 3:56:38 AM(UTC)
Replacement parts for MAYTAG MDB5600AWW | AppliancePartsPros.com
Here is a service manual and a tech sheet
http://www.servicematters.com/m...ibrary/docs/16021814.pdf
http://www.servicematters.com/m...ibrary/docs/16023063.pdf
Have you tried disconnecting power from the unit for an hour or so to see if it will reset?
Since all switches are dead odds are high that it is the control board.
I would check the ribbon cable into the board, see the Tech Sheet for the ribbon cable pin outs.
If the ribbon cable is the type that just has the bare cable at the end (no connector). I would clean it.
RIBBON CABLE CLEANING
Unplug the unit
Open it up
Remove the ribbon cable from the keypad to the control board at the control board.
Clean the edge connector.
If it is the type where there is not a connector just the insulation is removed, it can be cleaned with a pencil eraser. Do not use an ink eraser as it is too abrasive.
Check the tracks in the ribbon cable for hairline cracks. A magnifying glass helps here.
Would not hurt to clean the connector on the board. Use electronics contact cleaner or isopropyl alcohol and a tooth brush. Be gentle and do not reconnect till all the solvent evaporates.
Reconnect everything and give it a try.
If the keypad checks out OK then I would replace the control board.
jwes
#3 Posted : Monday, May 18, 2009 5:18:01 PM(UTC)
jwes
Cleaning the contacts on the ribbon connector where it attaches to the circuit board did the trick.
Thanks.
No power to control panel Kenmore Elite dishwasher model 665.12793k311 (Garbage Disposer Repair)
by John Boof 2/2/2022 6:56:51 PM(UTC)
No Power to Control Panel unless burner turned on (Oven Repair (including Ranges and Cooktops))
by rscotts3 11/25/2016 5:44:01 AM(UTC)
No power to control panel (Dishwasher Repair)
by alcarra 6/25/2012 12:32:49 PM(UTC)
Kitchen Aid Dishwasher will start and no power to control panel (Dishwasher Repair)
by dirt-tx 4/1/2012 4:14:32 PM(UTC)
No power to control panel (Washer Repair)
by amortellite 9/8/2011 2:24:00 PM(UTC)
No Power to Control Panel (Dishwasher Repair)
by ceking60 11/17/2010 11:10:24 AM(UTC)
Quiet Partner Two no power to control panel (Dishwasher Repair)
by jessejames1075 6/10/2010 10:00:35 AM(UTC)
Kitchen Aid Dishwasher KUDK01ILBS3 no power to Control Panel (Dishwasher Repair)
by saint01 12/8/2009 4:08:34 PM(UTC)
calypso washer no power to control panel (Washer Repair)
by shoomake 6/7/2009 7:06:34 PM(UTC)
