When starting the wash cycle, the water comes out but the agitator starts at the same time. When the water stops flowing in, the agitator stops also. Then it starts up for a few seconds and stops again. It keeps repeating this start and stop cycle. Is this my timer or the control board?
Garron
Hi Garron, Most likely the problem is a bad water level switch. Also I would check the wires inside the control panel. - The part number for the water level switch is AP3019660Gene.
