lk2101
#1 Posted : Sunday, May 3, 2009 7:32:09 AM(UTC)
lk2101
The microwave blows the ceramic fuse but not during operation. Everything works fine, then when I go to heat something again I notice there is no power to the unit and the fuse is blown. I've replaced the fuse twice. The micro. will work fine for many uses before it happens again.
applianceman
#2 Posted : Monday, May 4, 2009 6:17:34 PM(UTC)
applianceman
The monitor switch can cause this. The monitor switch is on of the three door switches and if it doesn’t work the fuse will blow. But because it’s intermitting it may be hard to check so you might want to just change it and see. Microwave Repair Guide
lk2101
#3 Posted : Tuesday, May 5, 2009 5:17:10 AM(UTC)
lk2101
Thank you for your help. I will check this out.
