AppliancePartsPros.com
Appliance Repair Help
Washer Repair
kenmore direct drive washer fills then only buzzes
My Kenmore Washing Fills Then Will Not Agitate Or Spin, Only Buzzes. Can You Help Me Diagnose?
The first think you want to check is the coupling, this part here. Part number: AP3963893
On your way into the machine, check the pump for an obstruction.
Originally Posted by: sidfink43 ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) The first think you want to check is the coupling, this part here. Part number: AP3963893
On your way into the machine, check the pump for an obstruction. Had to replace coupler a few months ago, working fine since. Lid switch works okay. Timer buzzes and won't advance on any setting. Will not drain either, fortunately the drain hose is a bottom feed and tub can be gravity drained.
Washer Repair
