thelazydentist
#1 Posted : Monday, December 3, 2007 12:33:22 PM(UTC)
thelazydentist
I'm trying to replace the clutch, I removed the 3 bolts that hold the motor/transmission in but the assy won't come out. I took the top and bottom agitator out. Now what?
Regards,
Charlie
#2 Posted : Monday, December 3, 2007 11:15:37 PM(UTC)
You have to remove the top ring (#6 on the agitator, basket and tub break down diagram).
Remove the spanner nut (#11 on the agitator, basket and tub break down diagram) and remove the basket.
Remove the drive block (#15 on the agitator, basket and tub break down diagram).
Now you can pull the transmission out.
To remove the spanner nut you need the spanner wrench.
clutch removal (Dishwasher Repair)
by phild 6/28/2008 7:24:47 PM(UTC)
