GE Profile Harmony Washer that just stopped working and gave me this: NOTICE! A problem has been detected with this unit. It gave me no error message number or anything. I've turned off and back on power, I unplugged it. Nothing!! Help please :)
Run the Service Test mode as described in the attached file and post the results. For a further assistance post the complete model number of the washer? Gene.
Originally Posted by: Gene  Run the Service Test mode as described in the attached file and post the results.
Gene. Thanks Gene, STEP 3 was the trick...pressing MY CYCLES and BACK simultaneously for 3 seconds. Apparently we have a Broken Clutch Coupling.
You are welcome. I'm glad you were able to diagnose the problem.
need help! have th same mmsg as gene, however the screen will not displayy anything else, get 2 beeps on all attenpts. when unit is first powered, numerus beeps sound. thx everyone, lb
Originally Posted by: amadorlb  need help! have th same mssg as gene, however the screen will not displayy anything else, get 2 beeps on all attenpts. when unit is first powered, numerus beeps sound. thx everyone, lb model # wpgt 9360eoww serial # dl400172m
