joshandelly
#1 Posted : 13 years ago
joshandelly
One of the cooktop knobs came loose on my range. So, I started to play with it and that caused a spark on the inside of the electric panel. The power went off and the breaker was tripped. After turning the breaker back on, the range is still not on. On the inside of the panel, there is a burn mark under the loose knob. Do I just need to replace the knob to bring power back or do I have a bigger problem now? Any suggestions...
Sorry the model is KERC607hwh5.
#2 Posted : 13 years ago
Originally Posted by: joshandelly Go to Quoted Post
...After turning the breaker back on, the range is still not on...
Can you describe more detailed what is On and what is Off?
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL KERC607HWH5 ELECTRIC FREESTANDING RANGE | AppliancePartsPros.com
joshandelly
#3 Posted : 13 years ago
joshandelly
The power on the whole range is off. The electrical panel is not working. I guess I'm wondering if the spark caused a break in the circuit and I just need to replace the knob or do you think that I fried something else as well.
#4 Posted : 13 years ago
There are no fuses for the whole range and the oven control board and the surface elements have separated controls. So if everything is dead, the first thing you may want to check is the voltage to the range. It suppose to be about 240 VAC.
joshandelly
#5 Posted : 13 years ago
joshandelly
Is there an easy way to check the voltage? I'm assuming you mean to check it at the outlet?
Josh
#6 Posted : 13 years ago
Yes Josh. That's right.
