suntree
#1 Posted : Friday, September 30, 2011 6:05:16 PM(UTC)
suntree
The interior light in the refrigerator part is not working. Replaced the switch. Replaced the bulb. Checked both with ohm meter so I know that both are good. What is the next thing to check?
#2 Posted : Saturday, October 1, 2011 3:45:23 PM(UTC)
Unplug the unit.
Remove the light bulb and look into the socket.
At the bottom you should see a small tab.
Bend that tab up. Sometimes they bend so it does not make contact with the center connector on the light bulb.
Be gentle as they break easily. Also make sure that it does not touch the sides of the socket.
