SpacemonkeyR
#1 Posted : Thursday, April 23, 2009 5:52:19 PM(UTC)
SpacemonkeyR
Sorry, I posted this in refrigerators by accident first.......
I hope Gene or someone can give me some sound advice. When you open the door, the light comes on. Close it and it goes off. Keypad works normal also. I can hear contacts closing when it is supposed to come on, and will stay pulled in while the timer counts down, and unlatches when it times out or stop is depressed. Oven does not come on. light does not come on while timer is counting like it does when it is running.
The control panel looks like it should come off without pulling the oven out, but doesn't have external screws. :confused:
So, CL, FM, and the GM from the wiring diagram are not coming on, but CL does come on when the door opens.
Thank you.
SpacemonkeyR
#2 Posted : Wednesday, April 29, 2009 6:45:24 AM(UTC)
SpacemonkeyR
FYI, the microwave is fixed. The upper primary switch was the culprit.
#3 Posted : Wednesday, April 29, 2009 11:12:12 AM(UTC)
We are glad you were able to fix it. Good job!
