I just had my washer and dryer moved to a new location. The dryer will run, but the gas will not ignite and heat. Under the front panel on the left side is a loose white wire which must have popped loose in moving. I have searched for a half hour and cannot find a spot this wire could have been connected to. If it grounds, the GFCI instantly tripps.
Anybody have an idea where this wire goes or have an available wiring diagram?
