splacido
#1 Posted: : Saturday, September 24, 2011 6:52:35 AM(UTC)
splacido
I have a amana DLW330RAW washer, The belt has burnt up and needs
to be replaced. How do I replace the belt?
sidfink43
#2 Posted : Sunday, September 25, 2011 4:29:54 PM(UTC)
sidfink43
You are going to have to remove the motor, then take the pump off. Also make sure you get the right belt as there may be several for this model depending upon which motor you have. You will need both your model number and your serial number.
Also see if you can determine why the belt burned up, and make sure you repair that problem.
SG1000 dryer belt replacement (Dryer Repair)
by Guest 6/28/2021 3:29:53 PM(UTC)
Belt replacement (Washer Repair)
by mgbwcw64 2/7/2015 9:24:59 AM(UTC)
WED7500VW belt replacement (no belt tensioner) (Dryer Repair)
by dafoster78 5/12/2014 1:56:12 PM(UTC)
Kenmore HE5 screeching sound...belt replacement/idler pulley or both? (Dryer Repair)
by kaikapoo 9/7/2013 5:56:19 PM(UTC)
Belt replacement help (Dryer Repair)
by applianceissues 3/11/2013 8:38:32 AM(UTC)
by garygordon 8/16/2012 7:43:56 AM(UTC)
Drive Belt Replacement (Washer Repair)
by mzulkoski 6/27/2012 12:49:20 PM(UTC)
Belt replacement (Dryer Repair)
by franpugh8767@hotmail.com 6/13/2012 9:14:24 AM(UTC)
WASHER belt replacement (Washer Repair)
by texaslonghorn 6/8/2012 8:42:47 PM(UTC)
by jerry388 4/14/2012 5:08:37 PM(UTC)
No ignition after interior clean and belt replacement (Dryer Repair)
by beek56 3/26/2012 6:10:14 PM(UTC)
Dryer Belt Replacement (Dryer Repair)
by John Osgood 3/18/2012 10:25:52 AM(UTC)
Drive Belt Replacement (Dishwasher Repair)
by TerryNi 3/7/2012 1:18:48 PM(UTC)
drive belt replacement (Washer Repair)
by RodE 1/22/2012 1:16:04 PM(UTC)
Washer Belt replacement (Washer Repair)
by spam_warrior 12/29/2011 4:56:13 PM(UTC)
