moovrs
#1 Posted : Monday, April 20, 2009 3:31:54 PM(UTC)
moovrs
Help - the lock button was stuck on and I was told to replace the control board. I just replaed the control board and now the normal light flashes and it runs for a minute and stops full of water. what now?
#2 Posted : Tuesday, April 21, 2009 5:12:04 AM(UTC)
Replacement parts for WHIRLPOOL GU1500XTLQ1 | AppliancePartsPros.com
Here is a service manual and a tech sheet
https://secured.whirlpoo...520548/$FILE/8178022.pdf
https://www.servicematters.com/d...0Sheet%20-%208537797.pdf
The above should help you diagnose the problem.
Try different cycle types re: where it does not look at the water temperature, as it may be waiting for the temp to rise tos certain level.
moovrs
#3 Posted : Wednesday, April 22, 2009 5:01:47 AM(UTC)
moovrs
Thanks for the repair manual - it is helpful.
The water is not getting hot. Not sure what to check next.
#4 Posted : Wednesday, April 22, 2009 5:54:12 AM(UTC)
I would check the heater with a meter to see if it has continuity. Should b3 10 to 35 ohms.
If OK
Check the HiLimit thermostat, should be 0 ohms
If OK
Check that the heater is getting voltage when it should (120 volts)
