MY OVEN STOP WORKING. IT DOESNT BOIL OR HEAT. MY STOVE TOP WORKS PERFERT. I HAVE REPLACED THE OVEN SWITCH AND THERMOSTAT. WHAT NEXT?:confused:
First, look to see if the breaker may be tripped. It's possible to have one side of the (doubled) breaker open, while the other is still operating.
Do you have a meter to check voltages and continuity?
Have you checked to see if the oven elements are good or not? You should be able to access their terminals from the rear of the oven.
