dwpjmp
#1 Posted : Monday, September 19, 2011 5:13:13 AM(UTC)
dwpjmp
You have been a member since:: 10/3/2009(UTC)
About a week ago the dryer would not start. Replaced the thermal fuse.
It worked fine for about 5 days and now it will not dry. No continuity on the thermal cut-off so it needs replacing.
I have the original internal-bias thermstat and the two internal connections have connectivity but the outer do not.
Is this normal?
More importantly could there be something else wrong that is causing a ripple effect? Am I looking at flushing money where more and more will continue to blow out or go wrong?
#2 Posted : Tuesday, September 20, 2011 3:29:28 AM(UTC)
[COLOR="Red"]DUPLICATE[/COLOR]
Please see the following
http://forum.appliancepartspros...thermostat-goes-out.html
Kenmore Dryer, Replaced fuse then days later thermostat goes out (Dryer Repair)
by dwpjmp 9/19/2011 5:14:09 AM(UTC)
