I am trying to identify the parts I will need to convert this microwave/rangehood unit from a vented unit to ventless. The unit was not correctly set up as a vented unit i.e. air is blown up into attic (which is a fire hazard) and it will be cheaper for me to obtain the parts to make it ventless than have someone vent it out through the roof as needed. Any help with identifying the correct parts, filters, etc or other ideas will be helpful. Cindy
:) Thanks so much Gene. Your reply had everything I needed. Cindy
You are welcome. I'm glad it solved the problem.
