tonia3238
#1 Posted : Tuesday, September 13, 2011 7:30:13 AM(UTC)
tonia3238
Have a whirlpool washer model#wtw5700sw0 that when the water temperature is set on cold the water changes temperature mid fill to hot.
When it is set on cold it is not in the acu temp mode so the water should just fill cold. would this issue be the actual switch or possibly the water valve itself?
sidfink43
#2 Posted : Wednesday, September 14, 2011 5:27:51 PM(UTC)
sidfink43
I cannot tell if there is ATC control in the valve assembly, if so it is probably the problem.
If not the timer or the selection switch can be the problem.
tonia3238
#3 Posted : Wednesday, September 14, 2011 5:41:21 PM(UTC)
tonia3238
Thank you so very much for your reply.
