paulgtwo
#1 Posted : Tuesday, November 27, 2007 9:11:04 AM(UTC)
paulgtwo
Motor and drum run, but no heat. Fuse checks good as do the two thermostates (continuity) across the terminals without wires on terminals.
Igniter and flame sensor both have continuity also. This style has the solid front, so I cannot see if the igniter is glowing. What do I need to check next?
#2 Posted : Tuesday, November 27, 2007 4:25:17 PM(UTC)
Remove the front panel but do not disconnect the wires from the door switch. Remove the drum, unplug the igniter, start the dryer and check for 120V to the igniter.
