Hi, my Maytag dishwasher will not drain. The drain line under the sink is high and secure. When I run the 'Normal cycle' it does not drain completely, yet when I run the 'Rinse Only Cycle' it drains completely? (Normal and Rinse only are two very separate settings on the dial.) Help? Thank you!
Originally Posted by: asf ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Hi, my Maytag dishwasher will not drain. The drain line under the sink is high and secure. When I run the 'Normal cycle' it does not drain completely, yet when I run the 'Rinse Only Cycle' it drains completely? (Normal and Rinse only are two very separate settings on the dial.) Help? Thank you! Possibly the control timer. since it drains with rinse cycle, the pump is working.
