My oven digital display on shows partial numbers, so my guess is that I need to replace the digital display. It is not clear to me how to access the display to replace it. I would appreciate some instruction on how to get the control panel off in order to access the dispaly unit.
Here are your parts Replacement parts for WHIRLPOOL KDRP407HSS4 RANGE-DUAL FUEL | AppliancePartsPros.comHere is a service manual which should help with dismantling. http://appliancedigest.c...tion-oven-service-manualYou have to join the site to download the manual but it is free and this is a very good site for manuals and other info for the appliance repair DIYer. Looks like the display is a separate device so you may want to try the following before replacing any parts. Connector Cleaning / Checking Unplug the unit Open it up Remove the ribbon cable from the keypad to the control board at the control board. Clean the edge connector. If it is the type where there is not a connector just the insulation is removed, it can be cleaned with a pencil eraser. Do not use an ink eraser as it is too abrasive. Check the wires and solder connections. Check the tracks in the ribbon cable for hairline cracks. A magnifying glass helps here. Would not hurt to clean the connector on the board. Use electronics contact cleaner or isopropyl alcohol and a tooth brush. Be gentle and do not reconnect till all the solvent evaporates. Reconnect everything and give it a try. |
THIS FORUM IS DEAD!!!!!!! |
