joevee
#1 Posted : Monday, April 6, 2009 3:39:53 AM(UTC)
joevee
Everything works, but all of a sudden numbers 6-0 do not work at all. Any suggestiosn?
Thanks,
JoeVee
#2 Posted : Monday, April 6, 2009 4:55:34 PM(UTC)
JoeVee,
The correction is to replace the key pad (aka a membrane switch). If you need the correct part number then post the complete model number of the microwave and the color of the key pad and/or control panel.
joevee
#3 Posted : Tuesday, April 7, 2009 3:09:24 AM(UTC)
joevee
Model number is: MH1150XM and the pad is white.
JoeVee
#4 Posted : Tuesday, April 7, 2009 11:34:47 AM(UTC)
There suppose to be one more letter and one more digit after "M" in the model number. Look inside the microwave.
joevee
#5 Posted : Tuesday, April 7, 2009 11:36:36 AM(UTC)
joevee
I got it from the owner's manual, so I'll look at the microwave. Unfortunately, I am away from home, traveling, so I should be able to respond by this saturday. Thank you for all your help.
JoeVee
joevee
#6 Posted : Wednesday, April 8, 2009 2:58:58 AM(UTC)
joevee
Got it: MH1150XMQ4
Thanks again....
JoeVee
#7 Posted : Wednesday, April 8, 2009 1:36:59 PM(UTC)
You are welcome. The part number for the control panel is AP3179599
Here are the break down diagrams and Replacement parts for WHIRLPOOL MH1150XMQ4 | AppliancePartsPros.com
Keep us posted.
joevee
#8 Posted : Thursday, April 9, 2009 2:59:55 AM(UTC)
joevee
Thanks again. I will install it as soona s it arrives and let you know the outcome. Hopefully it will resolve the issue. I assume the replacement procedure is pretty straight forward too.
JoeVee
joevee
#9 Posted : Monday, April 13, 2009 4:26:02 AM(UTC)
joevee
Gene...worked perfectly, thanks a lot....
Really appreciate it very much...
JoeVee
#10 Posted : Monday, April 13, 2009 1:01:28 PM(UTC)
I'm glad you were able to fix it.
